sizing of hot water circulation pumps
Hello
What guidelins should I follow when I size/ design a circulation pump for a central hotwater system for a building (hot water is used for plumbing uses showers etc...)?
RE: sizing of hot water circulation pumps
Remember as well, that you're essentially turning the domestic hot water system into a hot water heating system if the lines are uninsulated. I've seen installations where the uninsulated recirculating domestic hot water system was fighting the air conditioning all summer.
you therfore size the flowrate of the pump just to match the hetloss of the system?
It is made by several cos., such as Raychem & Thermon
A 350' length to handle a HW line will draw less than 20 amp (according to the Raychem program).
