Need Material Definitions
Hi Everyone,
I am using Cosmos Express to analyse a particular part.  I have been on MatWeb to get the info I think I need for particular materials.  The materials I am using are 4130 Chromoly, and 7075-T6 aluminum.  I am getting some wierd numbers and wanted to know if someone could post the "physical properties" of 7075 and 4130 that they use within Solidworks.  I just want to double check my definitions against other "tested" ones to make sure I am getting accurate results.
Thank You
Brandon
