Air bag doing work
Air bag doing work
My problem is probably more difficult to describe than it is to fix. I have 2 metal plates at most .75 in. apart and I need something to go in between them to push them apart quickly for a short time and then allow them to spring back to there original position. I need some sort of air bag to do the pushing. The area I have between the plates is 4 in. by 4 in. and it needs to operate at 100 psig but it only needs to push them apart with about 700 pounds of force. I need it to move the plates 1 in. further apart. What I need is find out where I can find small air bags that will take that kind of psi.
RE: Air bag doing work
http
Best regards
pennpoint
http:
http://www.pronal.com/html_en/index.php?kid=2402
http://www.iteks.fr
