Stainless Blades
Stainless Blades
All,
I am looking for a Series of Stainless that will take and hold a cutting edge on material of about 0.01" - 0.017" of thickness. It will be coated with an anti-stick material after grinding the edge. Also any recommendations on what type of grinding would be best. Chemical vs. Mechanical?
Rich.....
Rich.....
Richard Nornhold, PE
RE: Stainless Blades
The suitability depends on application.
http://www.welding-advisers.com/
Michael McGuire
http://stainlesssteelforengineers.blogspot.com/
Can you point me to where the "Sharp Tool Engineeing" forum is? I remeber seeing it once upon a time, but can't seem to locate it now.
Rich.....
That Forum isn't active the present time. Hopefully SS is still a material so lets try again.
I would post in either the "Material Engineering other Topics" under the "Materials Engineering" Banner or the "Steel and Stainless Steel Engineering" Forum under the " Engineering Forums by Industry" Banner.
Look in the subject block on the left hand side under the greeting for the Forum Lists.
Rich.....
Corrosion, every where, all the time.
Manage it or it will manage you.
http://www.trent-tube.com/contact/Tech_Assist.cfm
Michael McGuire
