BOM Balloons tied to an Isometric View
Is there any way to create BOM Balloons on an Isometric View or Section View that I have created and have them automatically update. When I select the view it says "Invalid view for showing BOM Balloons for the region".
I am new to Pro-E.
Thanks in advance for any info.
Troy Marker
I am new to Pro-E.
Troy Marker
RE: BOM Balloons tied to an Isometric View
In the absence of better advise; create a super simple assy and work with it. If you can't get it working you can email or post (possible here?) so someone can fix it and send it back with an explanation.
I had each views set to a separate simplified reps, which was causing the problem. I changed them both to the master rep and hid the components I didn't want shown via the component display functionality. I have my repeat regions set to the master rep, also.
FYI: I am using Wildfire 2.0.
Thanks. Mission Accomplished.
