Criterea for Special Widening and Overlay?
Does Anybody know where you can locate or the best way to modify a criterea file?
I need to do a special overlay & widening criterea file.  Basically I have set the profile, but I need to add some material to build out on existing ground to create a "shelf" to support the new material for the widening?  Any ideas where to look for a critera file to do this, or is it best to try to write a new one?  If so what is the best process to take.  Thanks in advance,
Brian
RE: Criterea for Special Widening and Overlay?
Brian,
Go to the NDOR Web Site and check the Download area in Roadway design. You might find what you are looking for.
Namdac
