Display Style
Display Style
Wildfire 2.0 - m130 - Drawing Mode
I have noticed that at times my drawings revert back to the Default/Default setting in the View Display selection. I select Display Style: No Hidden, Tangent Edges: Dimmed AND SAVE, the next time I open the drawing...tah-dah! BACK to the default.
Setting? Bug?
Anyone have the same problem?
Setting? Bug?
RE: Display Style
David
RE: Display Style
Datum, etc. ... Save status, maybe sometimes update sheet or all sheets? I do see random changes in datum visibility if changes are made to model layer status, but ~think~ update will synch everything again unless I've defined view dependent layer status.
RE: Display Style
Are these settings changing in the same drawing? Or when you start or open other drawings?
These defaults (settings) can be set in your drawing set up file (.DTL). If you change these in a drawing they only affect that drawing. You have to save the .DTL file for these setting to affect all drawings going forward. It will not affect drawings that are already made.
Tofflemire
