what's the standard cover the size larger than 72"
For butterfly valve, AWWA covers up to 72". What else cover larger? Thanks! Good weekend, everybody!
David
RE: what's the standard cover the size larger than 72"
David,
The ASME B16.1 standard has flange size range to NPS-96, while the AWWA C207 standard has flange sizes to NPS-144.
Check the design pressure ratings of each standard.  There are other international standards which could be applied.
