MS Word, AutoCAD, DWGeditor
This only peripherally pertains to this forum, but I thought someone here might have run into this.
Have many Word docs with embedded AutoCAD drawings in them. If we need to edit, we can double-click the drawing and AutoCAD will open. We can edit, save, and all is good.
I have a new machine, and primarily run SolidWorks. SolidWorks comes with a dwg-compatible application called DWGeditor, so I haven't installed AutoCAD. If I double-click on an AutoCAD graphic in Word, I get a "can't find that application" error. Tried to convert within Word, but there don't seem to be many options.
So, the question is: Is there any reasonable way to tell Word to open these AutoCAD objects in DWGeditor? I've posted this same question in the SolidWorks forum.
RE: MS Word, AutoCAD, DWGeditor
This is a Windows / Linux / OS thing.  You need to associate DWGeditor with DWG files.  This is often done when software is installed but perhaps DWGeditor did not do this.  DWGeditor may have a setting somewhere for it.  Otherwise, for Windows, go Start/Control Panel/Folder Settings, choose the File Types tab find and change the program assigned to dwg files or add the dwg file and association.
I don't think this is the problem. If I view a .dwg file in the Windows Explorer, it shows up as a DWGeditor file. So, Windows knows how to open them. The problem seems to be with Word. How can I tell Word to open the .dwg image with this replacement program?
If it was inserted as an AutoCAD file, I'm not sure how to get Word to use DWGeditor.  Does it work if you insert a drawing as a DWGeditor object?
Yes, it probably does, although I haven't tried it. The problem is that I have a lot of old Word docs that have AutoCAD objects inserted into them, and I can't seem to find a way to be able to edit them with my replacement program.
