joining and extending line
How do you join a bunch of line segments into 1 line, and can you also extend line in sketch?
thank you
thank you
RE: joining and extending line
question 2) Trim command (if it's really a line, and not a spline)
Professional and reliable CAD design engineering services - Specializing in Catia V4, Catia V5, and CAD Translation. Catia V5 resources - CATBlog
but where is the join command? could you be more specific?
thank you.
lets say , there are 2 sketches , and you want to join them , go to the generative shape design workbench and then choose insert + operations+ join choose the sketches from the tree ...then press ok.
and then if you make any changes just go to your sketch. apply the changes. it will update automatically .
But I was just asking for simple operation to connect broken line, so the opposite function of break line.
thank you
Type "C:join" in the white box in the lower right hand corner of your screen. Once the function is activated, look to see which icon lights up - or look for "join" in your help documents.
Trim is used to extend a line, which is preferable to joining, assuming that you're not joining into a polyline. (for clarification of what I meant earlier)
