Inch Screw Thread Text File
Does any one have a text file that contains the standard thread sizes for inch internal threads? Catia only has metric and this does me no good. If no one has a text file an example of the format to create a text file myself would also work. Any help would be great.
Thanks again
Thanks again
RE: Inch Screw Thread Text File
As soon as someone steps forth with a metric table, I'm going to post it at CATBlog. (and I may even make one, time permitting)
Professional and reliable CAD design engineering services - Specializing in Catia V4, Catia V5, and CAD Translation. Catia V5 resources - CATBlog
Nominal Pitch Pilot UNF
4.826 0.79375 4.0 10-32 UNF
6.35 0.9071 5.4 1/4-29 UNF
7.9375 1.0583 6.9 5/16-24 UNF
9.525 1.0583 8.4 3/8-24 UNF
11.1125 1.27 9.8 7/16-20 UNF
12.7 1.27 11.4 1/2-20 UNF
14.2875 1.4111 12.8 9/16-18 UNF
19.05 1.5875 17.4 3/4-16 UNF
22.225 1.8143 20.3 7/8-14 UNF
I intend to make public a screw thread file, available to anyone, and without the hassle of having to search through a forum, which may or may not have a good search engine.
Runz - your post was deleted, but you may go to CATBlog, and post it there. I welcome you to become a member. If you don't want to join, I can ensure that it will be posted, you will be credited, and it will be easily found by the world - not lost in a forum.
Thank you.
I signed up at CATBlog, but have not received an email with my password.
As soon as I receive the email, I will gladly post the thread files that I have.
This is a Ansi_UNC file
Copy paste this into a .txt file. Add the standard in the Threaded hole area.
Nominal Diameter(in) Pitch(in) Minor Diameter(in) Ref. Pitch Diameter(in)
0.073 0.0156 0.0561 1_64 UNC 0.0629
0.086 0.0179 0.0667 2_56 UNC 0.0744
0.099 0.0208 0.0764 3_48 UNC 0.0855
0.112 0.0250 0.0849 4_40 UNC 0.0958
0.125 0.0250 0.0979 5_40 UNC 0.1088
0.138 0.0313 0.1042 6_32 UNC 0.1177
0.164 0.0313 0.1302 8_32 UNC 0.1437
0.19 0.0417 0.1449 10_24 UNC 0.1629
0.216 0.0417 0.1709 12_24 UNC 0.1889
0.25 0.0500 0.1959 .25_20UNC 0.2175
0.3125 0.0556 0.2524 .3125_18UNC 0.2764
0.375 0.0625 0.3073 .375_16UNC 0.3344
0.4375 0.0714 0.3602 .4375_14UNC 0.3911
0.5 0.0769 0.4167 .5_13UNC 0.45
0.5625 0.0833 0.4723 .5625_12UNC 0.5084
0.625 0.0909 0.5266 .625_11UNC 0.566
0.75 0.1000 0.6417 .75_10UNC 0.685
0.875 0.1111 0.7547 .875_9UNC 0.8028
1 0.1250 0.8647 1.0_8UNC 0.9188
1.125 0.1429 0.9704 1.125_7UNC 1.0322
1.25 0.1429 1.0954 1.25_7UNC 1.1572
1.375 0.1667 1.1946 1.375_6UNC 1.2667
1.5 0.1667 1.3196 1.5_6UNC 1.3917
1.75 0.2000 1.5335 1.75_5UNC 1.6201
2 0.2222 1.7594 2.0_4.5UNC 1.8557
2.25 0.2222 2.0094 2.25_4.5UNC 2.1057
2.5 0.2500 2.2294 2.5_4UNC 2.3376
2.75 0.2500 2.4794 2.75_4UNC 2.5876
3 0.2500 2.7294 3.0_4UNC 2.8376
3.25 0.2500 2.9794 3.25_4UNC 3.0876
3.5 0.2500 3.2294 3.5_4UNC 3.3376
3.75 0.2500 3.4794 3.75_4UNC 3.5876
4 0.2500 3.7294 4.0_4UNC 3.8376
Derek
Here is a Ansi_UNF file.
0.073 0.0139 0.058 1-72 UNF 0.073
0.086 0.0156 0.0691 2-64 UNF 0.0759
0.099 0.0179 0.0797 3-56 UNF 0.0874
0.112 0.0208 0.0894 4-48 UNF 0.0985
0.125 0.0227 0.1004 5-44 UNF 0.1102
0.138 0.0250 0.111 6-40 UNF 0.1218
0.164 0.0278 0.134 8-36 UNF 0.146
0.19 0.0313 0.156 10-32 UNF 0.1697
0.216 0.0357 0.177 12-28 UNF 0.1928
0.25 0.0357 0.211 .25_28 UNF 0.2268
0.3125 0.0417 0.267 .3125_24 UNF 0.2854
0.375 0.0417 0.33 .375_24 UNF 0.3479
0.4375 0.0500 0.383 .4375_20 UNF 0.405
0.5 0.0500 0.446 .5_20 UNF 0.4675
0.5625 0.0556 0.502 .5625_18 UNF 0.5264
0.625 0.0556 0.565 .625_18 UNF 0.5889
0.75 0.0625 0.682 .75_16 UNF 0.7094
0.875 0.0714 0.798 .875_14 UNF 0.8286
1 0.0833 0.91 1.0_12 UNF 0.9459
1.125 0.0833 1.035 1.125_12 UNF 1.0709
1.25 0.0833 1.16 1.25_12 UNF 1.1959
1.375 0.0833 1.285 1.375_12 UNF 1.3209
1.5 0.0833 1.41 1.5_12 UNF 1.4459
Derek
In Microsoft Word, replace all spaces with the special character for tab, which is ^t.
Save it, and replace it.
CAD design engineering services - Catia V4, Catia V5, and CAD Translation. Catia V5 resources - CATBlog.
http://www.gewinde-normen.de/en/index.html
Fernando
