Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I love the structure of the site. You start at the top, and drill down to what you want. Maybe I've been using Unix too long... :-) "
Geography
Helpful Member!  albresco (Mechanical)
18 Dec 01 13:52
Is there a standard published to determine minimum turning radius required of semi and B-train truck and trailers for design of access lanes inside a manufacturing complex?
truck (Automotive)
17 Jan 02 22:44
It's a function of wheelbase, track, trailer length, drawbar length, and a number of other items. You need to take your vehicle and draw the curve you need.
Truck
bigallan (Structural)
14 Jun 02 13:57
I am also looking for this information. but no luck so far.
Why is it so difficult to determine?
Helpful Member!  rbaerg (Automotive)
4 Oct 02 3:22
You could look at SAE J695 "Turning Ability and Off Tracking - Motor Vehicles".  The "sum of squares" method is most commonly used to predict off tracking of a given vehicle.  The method is described in J695.
It is available through the SAE at www.sae.org
feadude (Mechanical)
11 Dec 04 13:32
Anyone has info on how to determine the turning radius of a trailer that has self steer axle in combo with fixed axles. The self steer axle has leading kingpin made by KGI and it is located on the very end of trailer. There are four fixed axles in front of KGI.
THANK YOU
rmw (Mechanical)
14 Dec 04 23:00
Turning radius is a function of wheelbase, steering gear geometry, placement of axles, and a host of other factors.
Unless the tractor/trailers you are wishing to analyze this for are identical, then you have to consider all possibilites regarding the types and varieties of tractor/trailers you are planning to bring into the area in question.
rmw
yogi3507 (Civil/Environmental)
16 May 05 13:34
There is a program called AutoTurn that can be used in AutoCadd or MicroStation.  It can track the wheel paths of all different type vehicles.  Many of them are already loaded in the program
Close Box
Join Eng-Tips® Today!
Join Us             Close
