Narrow Groove welding technical details.
I'm working on Narrow Groove Welding of Carbon Steel for pressure Vessels (SA 516 Gr. 70)
I donot want to go for Backing strip method. Hence prefer the Back gouging method.
Wanted to know from where can i get the Groove design detail and the consumable detail along with the current and voltage , speed settings for the same.
RE: Narrow Groove welding technical details.
http://www.aws.org/cgi-bin/mwf/forum_show.pl
Give us a little more info on process, material thickness, etc. and we may be able to help.
Your welding procedure for your pressure vessel will have to be per ASME Section IX.
ZCP
www.phoenix-engineer.com
Well the thickness of the vessel as mentioned above is 100mm and materail of const. SA 516 Gr. 70.
I don't have the copy mentioned by Carburize' "Developments in Pressure Vessel Technology-3" Edited by R W Nichols - Applied Science Publishers - London
I would be using SAW ( Submerged arc welding )
Would also like to know if any standard Nozzle design is available for Narrow Groove welding.
Thanks.
Qalab.
I'm using Submerged arc wekding for the welding of shell.
Plate matl.:- sa 516 Gr. 70
Thickness :- 100 mm
As mentioned by Carburize i don't have the following book.
Let me know if standard Nozzle design is available for the Narrow groove welding.
Qalab.
If your location is outside the US, I would highly recommend you contact esab (see below). These folks can help you with narrow groove submerged arc welding equipment and development for your shop application.
http:
Do you have square wave SAW power supplies or conventional supplies. Multi wire or single wire?
