questions about surface tension
Hi !
I am wondering what are the theoretical values for the surface tension of Nickel and Gold.
I am looking to do a "plating" (0,1 µm)of a silicon oxide layer on a gold, or nickel (not defined yet surface). What are the processes / equipment that could do the job ?
Thanks a lot for your advice.
John
RE: questions about surface tension
Zubaki:  I just joined and your post is a little old, so maybe my reply is too old to be useful.  But a high-performance SiO2 coating is readily applied by either a sol-gel process or a plasma polymerization.  I can give you more info if you want.....
