modeling stone check strucutres
I'm trying to estimate flow though a 250' long open grass channel at 4% slope with 0.5' high stone check structures placed at intervals of 50' along the channel.
I am wondering if you have ever seen Manning's n values for grass channels that account for the added retention capabilities of stone check structures? I'm hesitant to just pick a higher n value without somehow justifying my decision.
RE: modeling stone check strucutres
Treating this as a single channel routing would only apply if you have normal Manning's flow throughout the channel. This would require sufficient flow depth so that the check-dams are well submerged, and can be treated as part of the overall "roughness" of the channel.
If these assumptions are valid, you could estimate the overall Manning's value using the table on page 128 of the HydroCAD Owner's Manual. You might use a weighted average somewhere between 0.04 (for irregular rock cuts) and the appropriate value for the rest of the channel. You may even be able to find a table that applies more directly to your situation.
If in doubt about the final value, I suggest a simple sensitivity analysis to see how accurate you need to be for the specific objectives of your study.
