Radome search 24 inch diameter, 16" tall, sources??
I have need for a commercial antenna radome (1.5-1.6 Ghz) for shipboard/marine use.
After a bit of searching I found one at Andrew ($185) that's a hemisphere shape. Not bad, but I'm curious if anyone could suggest another source.
The optimum size is cylindrically shaped about 12"-16" tall x (18"-24" diameter) is preferred.
kch
kch
