Fact or Fiction: Dimpled Underbody helps reduction in drag
i'm sure you've seen the Lexus commerical claiming that a dimpled underbody reduces overall drag on the car, is it true? and how does it do it?
would vortex generators achieve the same benefit?
RE: Fact or Fiction: Dimpled Underbody helps reduction in drag
BMW use dimples on their mirrors, so the dimples may work at automotive Reynolds numbers.
Cheers
Greg Locock
Works on a golf ball!
Cheers
Greg Locock
I was lead to believe BMW originally used the dimples to help reduce wind noise generated by air passing between the mirror body and the A pillar.
The point, don't necessarily believe everything that Toyota advertises.
Regarding the question.. unless there is airflow seperation downstream we're looking to minimize, dimples and vortex generators create a lot of unnecessary drag. Compare a flat smooth panel under the car, and one with 80 vortex generators sticking out... may help in certain instances, but unless properly engineered, it will likely be a negative. We're trying to create low pressure under the car, and the extra turbulence may not help too much if you know what I mean.
Regarding the golf ball... let's model vortex generators on a golf ball and compare it to a dimpled golf ball!
