Simulation Software
Simulation Software
Simulation Software
Hello all,
My question is whether anyone has experience with other process simulation software other than Hysys/Aspen.  Specifically, something much more simple than Hysys and less expensive.
Our office (which deals in upstream oil and gas engineering) currently has a Hysys license but we really only use it to get material stream properties.  No distillation, no reaction, no detailed process design what-so-ever.  I just need something like a "Hysys-lite" that can perform simple VLE on standard hydrocarbon streams and give me stream properties.  The cost needs to be below $12,000-$15,000 per year.
I would appreciate any leads...
AK Oil'n'Gas
RE: Simulation Software
We use two products that might meet your needs:
Engineers Aide; (aka ChemPro, SiNet, System 7)
http://www.epcon.com/product121.htm
and
DF DesigNet; (aka Design Flow Solutions)
http://www.abzinc.com/
These programs are more designed for users who need a tool for hydraulic analysis (especially piping networks), physical properties, simple flashes, etc. The reason we license two is because we are currently looking at DesigNet to replace ChemPro.
best wishes,
sshep
We use WinSim's Design II for Windows, but it may be more than what you are looking for.
http://www.winsim.com/
Cheers!
MPritchett
As mpriychett says
Take a look at winsim/design II
Its got allmost everything that hysys has and a LOT cheaper.
Its even fairly easy to integrate the thermodynamic routines in excel sheets etc.
You can download a 2 week trial and theres even free introduction classes.
I use mostly HYSYS and winsim on occation but i have allways found winsim just as easy to use.
Best regards
Morten
Here is a relevant thread that might be very useful:
thread135-141211
For what you are trying to do, here's something to consider: a one-time payment gets you a permanent paid up license for a simulator called PD Plus.  This is a lot more power than you need, but it seems just the ticket considering the cost of the alternatives.  The cost for PD Plus was quite modest the last time I checked (under $2000).
The appropriate link for PD Plus is:
http://www.deerhaventech.com
Learning to use this is a cinch; however, if you need guidance, send me a problem and I'll either send you a PD Plus input file to solve it or simple instructions on how to do it.  Also, you won't believe this, but PD Plus users get help from the program author himself which itself is worth more than the cost of the program in my opinion.  I learned to use it in less than a week for REALLY complex refinery simulations.
The choice of a simulator for more complex engineering office environments than yours depends on many factors.  However, simple flashes, distillation columns, and normal unit operations can be handled by PD Plus very quickly and robustly.
Have fun.
