H2S Resistant Brazed Joints
I'm doing a little research on this project I'm working on. One application involves brazing a 316SS ring onto 13Cr pipe. Problem is, this thing will possibly see some high H2S environments (its going downhole). Now I've heard that even with a higher nickel content of braze, that the brazed joint might just be eaten away by the acid.
Does anyone know of any possible combinations of brazing metals that would be resistant to this kind of environment?
Jason
Jason
RE: H2S Resistant Brazed Joints
If you are really concerned just run a test. We put a braze alloy sample in a corrosive medium and weigh it before and after.
Tom
Thomas J. Walz
Carbide Processors, Inc.
www.carbideprocessor.com
