Cut list Macro
Cut list Macro
Cut list Macro
hi all,
I would like to be able to create cut list item folders for each member individually, and not have SW group them into one folder. The API help has a macro that allows one member to be selected, and then puts it in a folder. Is there a way to rework this macro or write a macro that will allow me to select all the members in the cut list and have them listed in separate folders? I'd like to not have to select them one at a time. Thanks.
RE: Cut list Macro
I just combined 2 macros from the API help and modified a few lines. Seems to work well. You'll need to delete any existing Cutlist Items before you run the macro tho.
If you're interested in what changes I did, look for lines that contain: *ADDED*, *DON'T NEED*, or *CHANGED*.
Enjoy,
Ken
CODE
'Select Bodies Example (VB)
'This example shows how to select both solid and surface bodies in either a part or an assembly.
' Preconditions: Part or assembly is open.
' Postconditions: All solid and surface bodies are selected.
Option Explicit
Public Enum swDocumentTypes_e
    swDocNONE = 0       '  Used to be TYPE_NONE
    swDocPART = 1       '  Used to be TYPE_PART
    swDocASSEMBLY = 2   '  Used to be TYPE_ASSEMBLY
    swDocDRAWING = 3    '  Used to be TYPE_DRAWING
End Enum
Public Enum swBodyType_e
    swSolidBody = 0
    swSheetBody = 1
    swWireBody = 2
    swMinimumBody = 3
    swGeneralBody = 4
    swEmptyBody = 5
End Enum
Sub SelectBodies(swApp As SldWorks.SldWorks, swModel As SldWorks.ModelDoc2, vBody As Variant, sPadStr As String)
    Dim swModExt                    As SldWorks.ModelDocExtension
    Dim swBody                      As SldWorks.Body2
    Dim sBodySelStr                 As String
    Dim sBodyTypeSelStr             As String
    Dim i                           As Long
    Dim bRet                        As Boolean
    If IsEmpty(vBody) Then Exit Sub
    Set swModExt = swModel.Extension
    For i = 0 To UBound(vBody)
        swModel.ClearSelection2 True '*ADDED*
        Set swBody = vBody(i)
        sBodySelStr = swBody.GetSelectionId
        Debug.Print "  " & sPadStr & sBodySelStr
        Select Case swBody.GetType
            Case swSolidBody
                sBodyTypeSelStr = "SOLIDBODY"
            Case swSheetBody
                sBodyTypeSelStr = "SURFACEBODY"
            Case Else
                Debug.Assert False
        End Select
        bRet = swModExt.SelectByID2(sBodySelStr, sBodyTypeSelStr, 0#, 0#, 0#, True, 0, Nothing, swSelectOptionDefault): Debug.Assert bRet
        If bRet Then '*ADDED*
            InsertWeldmentCutList swApp, swModel '*ADDED*
        End If '*ADDED*
    Next i
End Sub
Sub ProcessComponent(swApp As SldWorks.SldWorks, swModel As SldWorks.ModelDoc2, swComp As SldWorks.Component2, nLevel As Long)
    Dim vChildComp                  As Variant
    Dim swChildComp                 As SldWorks.Component2
    Dim swCompConfig                As SldWorks.Configuration
    Dim sPadStr                     As String
    Dim vBody                       As Variant
    Dim i                           As Long
    For i = 0 To nLevel - 1
        sPadStr = sPadStr + "  "
    Next i
    Debug.Print sPadStr & swComp.Name2 & " <" & swComp.ReferencedConfiguration & ">"
    ' Solid bodies
    vBody = swComp.GetBodies2(swSolidBody)
    SelectBodies swApp, swModel, vBody, sPadStr
    ' Surface bodies
    vBody = swComp.GetBodies2(swSheetBody)
    vChildComp = swComp.GetChildren
    For i = 0 To UBound(vChildComp)
        Set swChildComp = vChildComp(i)
        ProcessComponent swApp, swModel, swChildComp, nLevel + 1
    Next i
End Sub
Sub ProcessAssembly(swApp As SldWorks.SldWorks, swModel As SldWorks.ModelDoc2)
    Dim swConfigMgr                 As SldWorks.ConfigurationManager
    Dim swConf                      As SldWorks.Configuration
    Dim swRootComp                  As SldWorks.Component2
    Set swConfigMgr = swModel.ConfigurationManager
    Set swConf = swConfigMgr.ActiveConfiguration
    Set swRootComp = swConf.GetRootComponent
    ProcessComponent swApp, swModel, swRootComp, 1
End Sub
Sub InsertWeldmentCutList(swApp As SldWorks.SldWorks, swModel As SldWorks.ModelDoc2) '*CHANGED* Renamed and added variables
'Insert Weldment Cut List Example (VB)
'This example shows how to insert a weldment cut list in a weldment part document.
' Preconditions:
'       (1) Weldment part is open
'       (2) At least one solid body is selected in FeatureManager design tree.
' Postconditions:
'       (1) New weldment Cut-List-Item folder is created in the FeatureManager
'           design tree.
'       (2) Selected bodies are placed in the new folder.
'*DON'T NEED* since it's a subroutine    Dim swApp                           As SldWorks.SldWorks
'*DON'T NEED* since it's a subroutine    Dim swModel                         As SldWorks.ModelDoc2
    Dim swSelMgr                        As SldWorks.SelectionMgr
    Dim swFeatMgr                       As SldWorks.FeatureManager
    Dim swCutListFeat                   As SldWorks.Feature
    Dim nSelCount                       As Long
    Dim swBody()                        As SldWorks.Body2
    Dim i                               As Long
    Dim bRet                            As Boolean
    Set swApp = Application.SldWorks
    Set swModel = swApp.ActiveDoc
    Set swSelMgr = swModel.SelectionManager
    Set swFeatMgr = swModel.FeatureManager
    nSelCount = swSelMgr.GetSelectedObjectCount
    ReDim swBody(nSelCount - 1)
    For i = 1 To nSelCount
        Set swBody(i - 1) = swSelMgr.GetSelectedObject5(i)
    Next i
    Set swCutListFeat = swFeatMgr.InsertWeldmentCutList
    Debug.Print "File = " & swModel.GetPathName
    Debug.Print "  " & swCutListFeat.Name
    For i = 0 To nSelCount - 1
        Debug.Print "    " & swBody(i).GetSelectionId
    Next i
End Sub
Sub main()
    Dim swPart                      As SldWorks.PartDoc
    Dim i                           As Long
    Dim bRet                        As Boolean
    Select Case swModel.GetType
        Case swDocPART
            Set swPart = swModel
            ' Solid bodies
            vBody = swPart.GetBodies2(swSolidBody, True)
            SelectBodies swApp, swModel, vBody, ""
'*DON'T NEED*           ' Surface bodies
'*DON'T NEED*            vBody = swPart.GetBodies2(swSheetBody, True)
'*DON'T NEED*            SelectBodies swApp, swModel, vBody, ""
        Case swDocASSEMBLY
'*DON'T NEED*            ProcessAssembly swApp, swModel
        Case Else
            Exit Sub
    End Select
End Sub
RE: Cut list Macro
WOW that is incredible. It works great!!!!
I'd love to take some training on the API so i can understand what you did here.... :)
Thanks so much for taking the time to help out.
Best Regards,
Tony
RE: Cut list Macro
There was a macro to select all bodies. There was a macro to create a Cutlist Item and move the selected body into the Cutlist Item.
I just took the Select Body macro and made it so that each time it selected a body, it then runs the create Cutlist macro (which I had actually pasted inside the Select Body macro as a subroutine). Next clear all selections and then wait for the Select Body macro to find the next body...etc...
Ken
RE: Cut list Macro
KenBolen,
Is there a way to edit this macro so that the cutlist item folder that is created will inherit the NAME of the member it contains rather than Cut-List-Item(2)?
Thanks!
RE: Cut list Macro
Sure. Use the updated code below.
Ken
CODE
' EachBodyToCutlistItem.swp
' Preconditions:
'       (1) Part is open.
' Postconditions:
'       (1) Each solid body is put in a separate Cut List Item.
'       (2) Each Cut List Item is renamed to match the name of the contained solid body.
Option Explicit
End Enum
    swSolidBody = 0
    swSheetBody = 1
    swWireBody = 2
    swMinimumBody = 3
    swGeneralBody = 4
    swEmptyBody = 5
End Enum
    Dim i                           As Long
    Dim bRet                        As Boolean
'*DON'T NEED* Only for Debug        Debug.Print "  " & sPadStr & sBodySelStr
            Case swSolidBody
            Case swSheetBody
            Case Else
                Debug.Assert False
        End Select
            InsertWeldmentCutListItemSub swApp, swModel '*ADDED*
        End If '*ADDED*
    Next i
End Sub
    Dim i                           As Long
    Next i
    ' Solid bodies
    ' Surface bodies
    Next i
End Sub
End Sub
Sub InsertWeldmentCutListItemSub(swApp As SldWorks.SldWorks, swModel As SldWorks.ModelDoc2) '*CHANGED* Renamed and added variables
' Preconditions:
' Postconditions:
'           design tree.
    Dim i                               As Long
    Dim bRet                            As Boolean
    Dim swCutListFeatNameBefore As String '*ADDED*
    Dim j As Integer '*ADDED*
        swCutListFeatNameBefore = swCutListFeat.Name '*MOVED*
        swCutListFeat.Name = swBody(i - 1).GetSelectionId '*MOVED*
        j = 1 '*ADDED*
        While swCutListFeatNameBefore = swCutListFeat.Name '*ADDED*
            swCutListFeat.Name = swBody(i - 1).GetSelectionId & "-" & j '*ADDED*
        Wend '*ADDED*
    Next i
'*DON'T NEED* Only for Debug    Debug.Print "File = " & swModel.GetPathName
'*DON'T NEED* Only for Debug    Debug.Print "  " & swCutListFeat.Name
'*DON'T NEED* Only for Debug    For i = 0 To nSelCount - 1
'*DON'T NEED* Only for Debug        Debug.Print "    " & swBody(i).GetSelectionId
'*DON'T NEED* Only for Debug    Next i
End Sub
Sub main()
    Dim i                           As Long
    Dim bRet                        As Boolean
        Case swDocPART
            ' Solid bodies
        Case swDocASSEMBLY
        Case Else
            Exit Sub
    End Select
End Sub
RE: Cut list Macro
Sweet, this works great!. one question though. when i run the macro, it adds a -1(1) after the name of the member. Can this information be taken out? I know the () number usually comes in, but i've never seen the -number before. Thanks again, your help is saving me a ton of work! :)
RE: Cut list Macro
No it can't be taken out. The reason it does this is because a Cut List Item is a Feature. So if you already have a Feature (say Extrude1) by that name...you can't re-use that same name on another Feature (the macro makes it Extude1-1).
I noticed I had a line missing that would make the "-1" into a "-2"  etc. if there was already a "-1" Feature name in existance. The above macro will get stuck in a continuouse loop if that were to happen. I corrected it below. I could further modify it to insert spaces rather than "-1", "or "-2, or "-3", etc. At least to a user it would "look" like the name you want.
Ken
CODE
' Preconditions:
'       (1) Part is open.
' Postconditions:
Option Explicit
End Enum
    swSolidBody = 0
    swSheetBody = 1
    swWireBody = 2
    swMinimumBody = 3
    swGeneralBody = 4
    swEmptyBody = 5
End Enum
    Dim i                           As Long
    Dim bRet                        As Boolean
            Case swSolidBody
            Case swSheetBody
            Case Else
                Debug.Assert False
        End Select
        End If '*ADDED*
    Next i
End Sub
    Dim i                           As Long
    Next i
    ' Solid bodies
    ' Surface bodies
    Next i
End Sub
End Sub
' Preconditions:
' Postconditions:
'           design tree.
    Dim i                               As Long
    Dim bRet                            As Boolean
        j = 1 '*ADDED*
            j = j + 1 '*ADDED*
        Wend '*ADDED*
    Next i
End Sub
Sub main()
    Dim i                           As Long
    Dim bRet                        As Boolean
        Case swDocPART
            ' Solid bodies
        Case swDocASSEMBLY
        Case Else
            Exit Sub
    End Select
End Sub
RE: Cut list Macro
OK, but all of my members will be different names i.e. 2X6, 3X3, 2X4 ETC, but i notice it still puts the -number in even though they are different?
