Stress intensity factor
Can anyone help to clarify an issue I have with the concept of stress intensity factor in fatigue analysis.
A crack will only grow when the value of 'K' reaches a critical value 'KIC'.
or
A material will fail completely if 'K' reaches 'KIC'
or
RE: Stress intensity factor
Kic is the planein fracture toughness of a material, relevant to thick, heavy sections. thin sheet has a (much) higher toughness (called plane stress).
so the first statement is incorrect (cracks grow at stress intensities less than Kic; this is stable crack extension and occurs at stress intensities greater than "threshold")and the second is sometimes correct (some sections will fail at Kic, others will sustain higher stress intensities).
Also "fail" is a little tricky. in some structures (typically wings) the skin can initial dynamic crack growth (stress intensity exceeds the critical value) but then the crack is arrested by the stiffening elements (stringers) so that the structure doesn't necessarily "fail" when the crack goes unstable.
that's correct as far as it goes ...
Kic is the plane strain fracture toughness of a material, relevant to thick, heavy sections. thin sheet has a (much) higher toughness (called plane stress).
so the first statement is incorrect ... cracks grow at stress intensities less than Kic; this is stable crack extension and occurs at stress intensities greater than "threshold"
and the second is sometimes correct ... some sections will fail at Kic, others will sustain higher stress intensities depending on geoemtry (thickness).
Also "fail" is a little tricky. in some structures (typically wings) the skin can initiate dynamic crack growth (stress intensity exceeds the critical value) but then the crack is arrested by the stiffening elements (stringers) so that the structure doesn't necessarily "fail" when the crack goes unstable.
