Another Scale Issue
Another Scale Issue
Another Scale Issue
I am tring to get an MDT model into SW06. I step it out of MDT and then open the step file in SW06. The model comes in scaled down 1/25.4. In other words, what was drawn as 1" in MDT comes in as 0.0393700787401575 blah blah blah.
It does not happen with all files.
What am I doing wrong?
Thanks for your help.
Ken.
RE: Another Scale Issue
O.K. - My bad.
I found a setting in MDT for establishing scale of a step file.
Problem solved. It's an MDT issue.
- Ken.
This is why I am for only 1 CAD program in a company.
Happy you worked it out. Good luck.
Chris
Systems Analyst, I.S.
SolidWorks/PDMWorks 05
AutoCAD 05
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
The factor you are talking about is the difference between metric and english units.  one inch = 25.4 mm.  When you open the file in SW you should have an option for metric or english units.  Choose the opposite one and I think it will be at the correct scale.  You may also have an option when saving from MDT to chose the units?
Rob Rodriguez CSWP
President: Northern
Vermont SolidWorks User Group
www.robrodriguez.com (updated 1/30/06)
SW 2006 SP 3.0
