Unable to see working window display for part????
Hi
I'm currently having problems with solid edge. When i start it up everything seems fine, the edge bar loads and parts load but you just can't see them. The separate windows all appear to be blank for each part. I have the same problem now that i have V17. Have i deleted something from my computer to prevent me viewing the work screen??
Any help would be much apreciated.
Jo
RE: Unable to see working window display for part????
I encountered the same problem a while ago: 3 parts did
not show up in SE neither in .asm nor as .par. In both
cases they where visible in EdgeBar but I could not select
them. I ran OpenSave on all of them and that cured the
problem with 2 .par but one was obviously so damaged
that I had to start over with it.
OpenSave can be found in:
  C:\Program Files\Solid Edge V17\Custom\OpenSave
dy
Thanks for that but my problem is a bit worse. When i load up solid edge (both V15 &V17)the edge bar loads and a working window appears. But in this window where you would usually see a ble background are the axis, nothing appears. If you hover over the window with the mouse it can recognise which plane you are on.
Thanks for that but my problem is a bit worse. When i load up solid edge (both V15 &V17)the edge bar loads and a working window appears. But in this window where you would usually see a blue background and the axis, nothing appears. If you hover over the window with the mouse it can recognise which plane you are on.
jobennett,
Are you loading multiple parts ?
If so, it could be a graphics problem.
Try just one part on it's own.
Have the solid bodies been hidden in the files ?
bc
It happens when i'm starting a new part. Old parts do not load either?
Cheers Jo
