membrane surface calculation
an actual proces feed contains 1 wt% component, the productconcentration should be 15 wt%/ Flow rate =5m^3/h. Membrane is ideally mixed and continuous proces.
How do i calculate the surface that i need to install if i have the mass transfer coefficient?
RE: membrane surface calculation
