estimating the weight of a chemical plant
Hi folks,
in order to estimate the scrap refund to be expected from a total plant demolition just a brief question.
Is 100 to 200 kg per m3 plant volume a realistic number for an open steel structure?
What is your experience?
I look forward to your answers.
Kind Regards,
hahor
Kind Regards,
hahor
RE: estimating the weight of a chemical plant
Raymond
Raymond Hagedoorn
Cost Engineer
thank you for trying to help me.
We need some resonable ratios for guessing the weight of steel structure including equipment.
For example:
empty structure 40 ... 50 kg/m3
with pumps and light equipment: 70 ... 100 kg/m3
and so on
Many thanks in advance.
Kind Regards,
hahor
