How to find a 'hidden' part in a directory tree
In the past, I've always known which part I've hidden, and so I knew where to go in the assembly model tree, to 'show' my missing part.  But now that I've inherited a few models, I don't know where, or even which parts are hidden.
Is there a way to display a list of hidden parts, or is there a way to show- all?  Or how would someone else go about resolving my little problem?
RE: How to find a 'hidden' part in a directory tree
There is no way to show a list of hidden items.
To show-all:-
Select (highlight) the Top Level assy in the FM, then Edit > Show (or Show with depepndants) then select the configuration option.
cheers
Helpful SW websites  FAQ559-520
How to get answers to your SW questions  FAQ559-1091
The Display Pane in SW2006 helps with this - but you still need to know where to look.
Expanding the Display Pane from the FM tree makes it easier, IMO, to see what's hidden and what's not, but the FM tree will need to be fully expanded.
CBL,
Do you actually have Edit > Show with dependants? It was in SW2004, but didn't work (only Unsuppress with dependants worked). We never upgraded to SW2005. Now in SW2006, only Edit > Show is there. Do you see the same thing?
Ken
Nella95,
There is a macro in the SW2006 API Help called "Make All Assembly Components Visible Example". There is also an macro for "Only Show Selected Components Example".
Both work great.
Ken
This Excel macro will transverse the assembly and give information about parts and subassemblies: assembly level (Nível); file structure (Componente); configuration (Config.); doc type (tipo); supressed state (Supressão); hide state (Visibilidade); constraint state (Montagem).
It is very useful to keep track of supressed or hided parts/subassemblies.
Just create a macro button in the excel sheet called "Assembly". Some words are in Portuguese but I think you can figure out the appropriate english words.
Dim ErroConf As Integer
Dim RootComponent As Object
Private Sub CommandButton1_Click()
    Dim swApp As Object
    Dim AssemblyDoc As Object
    Dim Configuration As Object
    Dim linha As Integer
    Dim linhafim As Integer
    Dim linhatab As Integer
    Dim ConfNome As Variant
    Dim nivel As Integer
    Set swApp = CreateObject("SldWorks.Application")
    Set AssemblyDoc = swApp.ActiveDoc
    ErroConf = 0
    'On Error GoTo erro1
    Set Configuration = AssemblyDoc.GetActiveConfiguration()
    Set RootComponent = Configuration.GetRootComponent()
    ConfNome = Configuration.Name()
    ' novo método de limpeza da folha
    Worksheets("assembly").Range("A1:IV65536").ClearContents
    Worksheets("assembly").Select
    If AssemblyDoc.GetType <> 2 Then
        MsgBox "Por favor active uma Assembly no Solidworks"
        Exit Sub
    End If
    Worksheets("assembly").Range("I2").Value = "EM EXECUÇÃO"
    ' títulos das colunas de dados dos componentes
    linha = 4
        Worksheets("assembly").Range("A" & linha).Value = "Nível"
        Worksheets("assembly").Range("B" & linha).Value = "Componente"
        Worksheets("assembly").Range("C" & linha).Value = "Config."
        Worksheets("assembly").Range("D" & linha).Value = "Tipo"
        Worksheets("assembly").Range("E" & linha).Value = "Supressão"
        Worksheets("assembly").Range("F" & linha).Value = "Visibilidade"
        Worksheets("assembly").Range("G" & linha).Value = "Montagem"
    ' análise recursiva dos componentes
    If Not RootComponent Is Nothing Then
        TraverseComponent 1, RootComponent
    End If
    ' determina o comprimento dos dados
    linha = 5
    Do While (Worksheets("assembly").Cells(linha, 1).Value <> "")
        linha = linha + 1
    Loop
    linhafim = linha
linha = 5
'fim de listagem
    Worksheets("assembly").Range("I2").Value = ""
    Worksheets("assembly").Cells(linhafim + 1, 1).Value = "FIM DE LISTAGEM"
    Worksheets("assembly").Cells(linhafim + 2, 1).Value = "Total de " & (linhafim - 1) - linha + 1 & " componentes"
    Worksheets("assembly").Cells(linhafim, 1).Select
If ErroConf = 1 Then MsgBox "ATENÇÃO!" & Chr$(13) & "Existem peças/conjuntos com configurações com o nome 'Default'." & Chr$(13) & "P.f. corrigir."
Exit Sub
erro1:  MsgBox "Não é possível criar lista de peças. Verifique se:" & Chr$(13) & "1- a Assembly é válida" & Chr$(13) & "2- não é necessário um Rebuild" & Chr$(13) & "3- as propriedades de massa estão recalculadas"
End Sub
Private Function TraverseComponent(nivel As Integer, Component As Object)
    Dim i As Integer
    Dim Children As Variant
    Dim Child As Object
    Dim ChildCount As Integer
    Dim ModelDoc As Object
    Dim Subestrutura As String
    Dim CompConf As Variant
    ' activa dados do componente
    Set ModelDoc = Component.GetModelDoc()
    ' determina a configuração utilizada do componente
    CompConf = Component.ReferencedConfiguration()
    ' escreve dados na lista de peças, se existirem
    SubAddNameToSheet CompConf, nivel, Component
    ' verifica se o componente é um subconjunto e analisa recursivamente os "filhos"
    Children = Component.GetChildren
    ChildCount = UBound(Children) + 1
    'análise recursiva dos subconjuntos
    For i = 0 To (ChildCount - 1)
        Set Child = Children(i)
        Set ModelDoc = Child.GetModelDoc()
        If Not ModelDoc Is Nothing Then Subestrutura = ModelDoc.GetTitle()
            TraverseComponent nivel + 1, Child 'analisa recursivamente os "filhos"
    Next i
End Function
Private Sub SubAddNameToSheet(ConfNome As Variant, nivel As Integer, componente As Object)
    Dim colcontrol As Integer
    Dim EstadoSupr As String
    Dim Visibilidade As String
    Dim Montagem As String
    Dim ModelType As String
    Dim teste As Integer
    Set ModelDoc = componente.GetModelDoc()
        If ModelDoc.GetType = 2 Then
            ModelType = "ASM"
        Else
            ModelType = "PRT"
        End If
    Else
        ModelType = "?"
    End If
    linha = 5 ' 1ª linha de dados da lista de peças
    colcontrol = 2 'coluna que controla a escrita de componentes
    ' detecção da linha livre para escrita de componentes
    Do While (Worksheets("assembly").Cells(linha, colcontrol).Value <> "")
        linha = linha + 1
    Loop
        'determina o estado de supressão
        If componente.GetSuppression = 0 Then
            EstadoSupr = "suprimido"
        ElseIf componente.GetSuppression = 1 Then
            EstadoSupr = "lightweigth"
        ElseIf componente.GetSuppression = 2 Then
            EstadoSupr = "OK"
        Else
            EstadoSupr = "indeterminado"
        End If
        'determina o estado de visibilidade
        If componente.IsHidden(True) Then
            Visibilidade = "escondido"
        Else
            Visibilidade = "OK"
        End If
        'determina o estado de montagem
        If componente.GetConstrainedStatus = 1 Then
            Montagem = "montagem incorrecta"
        ElseIf componente.GetConstrainedStatus = 2 Or componente.GetConstrainedStatus = 0 Then
            Montagem = "não montado"
        ElseIf componente.GetConstrainedStatus = 3 Then
            Montagem = "OK"
        Else
            Montagem = "hiper restringido"
        End If
        'escreve dados
        Range("A" & linha).Select
        ActiveCell.FormulaR1C1 = "" 'faz o scroll à folha à medida que escreve linhas
        Worksheets("assembly").Cells(linha, 1).Value = nivel - 1 ' compatível com ProdStar
        Worksheets("assembly").Cells(linha, 2).Value = componente.Name 'Model.GetTitle & ">" & ConfNome
        Worksheets("assembly").Cells(linha, 3).Value = ConfNome
        Worksheets("assembly").Cells(linha, 4).Value = ModelType
        Worksheets("assembly").Cells(linha, 5).Value = EstadoSupr
        Worksheets("assembly").Cells(linha, 6).Value = Visibilidade
        Worksheets("assembly").Cells(linha, 7).Value = Montagem
  End Sub
