Triaxial Compression Testing vs Direct Shear Testing
Which is the preferred method of measuring shear strength in the lab – triaxial compression testing or small scale direct shear testing? Is the answer to this question at least partially application specific (irrespective of legal design requirements)?
Here is an excerpt from Holtz and Kovacs (section 10.5) that addresses this issue:
The advantages of the triaxial test over the direct shear test are:
??Progressive effects are less in the triaxial.
??The measurement of specimen volume changes are more accurate in the triaxial.
??The complete state of stress is assumed to be known at all stages during the triaxial test,
whereas only the stresses at failure are known in the direct shear test.
??The triaxial machine is more adaptable to special requirements.
The advantages of the direct shear test are:
??Direct shear machine is simpler and faster to operate.
??A thinner soil sample is used in the direct shear test, thus facilitating drainage of the pore
water from a saturated specimen.
I would also like to add a few other items others have pointed out:
(1) If designing on residual shear strengths, direct shear tests are preferable because of the longer travel distances.
(2) For samples with low void ratios (typically normally to overconsolidated calay-silt samples), pore pressure effects in direct shear tests are negligible.
I have pondered the answer to this question for a long time. Please share your opinions.
Rob
Rob
RE: Triaxial Compression Testing vs Direct Shear Testing
The TX test is pretty much useless for residual strength because you can't get enough strain. With DS, you can pre-cut a specimen with piano wire, cycle it back and forth a little, and measure a pretty good residual friction angle. DS is also quick to run, and requires less investment and operator skill.
It's like asking "Which is better, a motorcycle or a sailboat?"
Bigh I appreciate your comments regarding the shear strength relative to the slip surface. What Section of Lamb & Whitman were you refering to?
In reality, here in So Cal direct shear testing is still the standard when it comes to residual shear strength testing of slide gouge, bedding planes, etc.
