Hydraulic Piston twist
If you have a clevis that is just screwed on and not locked, on the end of a piston rod. Could the rod twist and unscrew the clevis (the clevis can't rotate)?
RE: Hydraulic Piston twist
I barely ever use them and haven't had one come apart yet.
Barry1961
I've used this extensively in the field, never a problem. The glue itself is like a Crazy Glue, so very strong. You can pick up a small bottle at any fastener supplier, inexpensive and practical.
Kenneth J Hueston, PEng
Principal
Sturni-Hueston Engineering Inc
Edmonton, Alberta Canada
