Steering geometry 4-wheel vehicle
I am working on a development project of a disbled 4 wheel scooter. The vehicle will only steer with both front wheels. Maximum speed is 15 km/h. My idea is to apply ackerman steering with KPI and Caster. What is a good value (3D) suspension program to determine the complete geometry?
Thanks!
Sjoerd
RE: Steering geometry 4-wheel vehicle
Susprog3d, if your suspension architecture is one of the ones modelled. Download the demo and find out. See the FAQ section for other suggestions.
You may want to model both steering LOADS and returnability from full lock, in which case you'll need a full vehicle model.
Cheers
Greg Locock
Thanks for the information Greg. I have downloaded the program and will have a go.
I don't know what you mean with 'steering loads' and 'full lock'. Could you explain these shortly?
Thanks.
Sjoerd
Briefly, the torque required to turn the steering wheel (SWT), and the tendency for the steering wheel to return to the straight ahead position by itself.
Cheers
Greg Locock
