Helix creation following a spline
Help. I need to create a helix that will follow a 3D spline rather than a axis. I have tried the helix command in GSD but cannot make it follow anything but a line or vector. Any ideas?
RE: Helix creation following a spline
Run a circular profile through the spline and then do an intersect between the circular profile and the second sweep.
The intersect curve will give you a helix along a spline.
Hope this helps.
