Small Vessel Question
I have a 50 gallon glass lined steel vessel.
The jacket on the vessel has developed a hole in it.
The vessel and jacket are ASME rated. Since the jacket is so small I am wondering if it is ok to just repair it in house and hydro test it to 1.3x design pressure?
Comments. Code rules?
StoneCold
StoneCold
RE: Small Vessel Question
Brian
Therefore we can repair the vessel in house and test it with out bringing in an R Stamped welding contrator.
Is that technically true or am I stuck with an R stamp repair?
1.What does it contain? What pressure? See SecVIII Div1 U-1.
2.Contact your local Juridiction and maybe the Fire Marshall/Chief.
3.Contact your Insurance Carrier.
If these all agree and you do a non R stamp repair,remove the ASME markings.
Just remember to consider possiable liabilites if some later goes wrong.
As far as it developing a hole, this could be a single isolated pit or could be due to corrosion over a larger area- don't just assume that repairing the leak makes it safe. It's like a leaky tire, it can have a nail hole or it can just be a worn out tire that finally started leaking in one spot.
Brian
I guess I am off to find a local R stamp holder and then hydro the little beast.
StoneCold
http://www.codeprep.com/ed_nbic_vs_api.htm
