Selection Filter - How Can I select only dimension?
For years, I have used I-deas, and now I chance to Catia, so, How Can I select only dimensions in sketch? And Is there anyway to edit multi-dimensions at same time?
I've used V5R13-SP4 on Sun Ultra HW.
Sparck
Sparck
RE: Selection Filter - How Can I select only dimension?
In the tree, if you expand the sketch you'll see a branch called Constraints. Just select that branch.
Another way you can select only certain geometry, etc, is to use your search function. To do this press CTRL+F (look familiar?) or go to EDIT Search from your menu. Now select what you want to select, click the Bino's and click SELECT when done.
