Bond symbols on drawings.
What symbols are used to identify the bonding process on assembly drawings. I've got a mesh in contact with a flat surface. The contact points are one inch by one inch, each requiring spot bonding.
A leader with direction to the notes?
Any help will be greatly appeciated. Thanks
tod.lewis@svtnsg.com
RE: Bond symbols on drawings.
Surface preparation
Temperature limits
Sequence
Primers
Amount and type of adhesive
Clamping
Cure time (UV intensity if using a UV cure product)
