IGES out Assembly part
All,
I know some things have changed in NX3. I need to know how to Export an entire Assy. NX2 was just Export,Iges,Specifiy File,OK.
I can export single parts in the Assembly as work parts but not the Assy
Any help would be great
Dwoody1
Dwoody1
RE: IGES out Assembly part
I have done this and the translator runs but I don't get all the geometry. Is there any other way. I have even tried using class selection and picjing the assembly file from the menu.
Woody
What jec3300 has suggested should work, however, if you are still having problems you can wave link the individual parts into the assy and then try to export. I've done this in the past and it has worked. good luck
Take care..
Can you explain how to do this. My UG is not so good.
Take care...
Open a new part - then file/import/parasolid
this breaks all links and treats each item as a solid body.
From there you can file/export/igs with no problem.
