How to highlight a cell giving a result greater or less than desired
3
To highlight a cell by changing from black to red when daily level readings are plus or minus 5mm from the origional datum level.
RE: How to highlight a cell giving a result greater or less than desired
3
Use format -> conditional formatting.  Use the "not between" test and highlight if the values are out of your range.
Hope this helps.
Worked a treat.  Thanks GensetGuy
