Arc Flash Evaluation for Single Phase Equipment
I was wondering what people are doing as part of arc flash evaluations when you have both 3-phase and single-phase equipment (panels, etc.) My experience is that some arc flash software ignores single phase equipment and that it is somewhat ignored in NFPA-70E. It seems silly to have a HRC/PPE specific label on a 3-phase panel and have a single-phase panel right next to it with no label. Any thoughts?
RE: Arc Flash Evaluation for Single Phase Equipment
The standard allows you to ignore xfmr's below 125kVA (480-208/120V systems).
Mike
They have arcflash shareware ("Duke Power Heat Flux Calculator") that allows for 120VAC calculations.
David Baird
Sr Controls Designer
EET degree.
Journeyman Electrician.
IEEE-1584 recommends that ALL 240V systems be evaluated. For 208V systems, they recommend evaluation for systems 125 kvA and larger. 240V and 208V are treated differently.
