BOM Table in Drawing??
Folks,
There is probably a very simple answer to this but here goes;
How does one create a BOM (Bill of materials) as a Table in an assembly drawing?
Surely there is a standard BOM Table within pro-e that I can use. I went throughh the help menu but??? I did a search on this site and found something about "repeat parameters" in standard tables.
Appreciate any help.
Speedy
Speedy
RE: BOM Table in Drawing??
This is a good place to start.
www.proece
Unfortunately with Pro/E, you have to build your BOM tables from scratch. Once you have done it once and saved it in a format, it will always be there when you want it and from that point, you can customize it with relations and filters for your specific needs.
Cheers,
JW
