Richards Valves
Richards Valves
Richards Valves
I have a spread sheet with the valves for a project listed.
It calls for a 300# ansi flanged 80dn ball valve, it then goes on to give the trim code as 080-SBBTST /00, I suspect that this code is not righ, to analise the trim code you need "Richards Selection Guide PIM-AA-05", I cant find this document anywhere on the web.
Here is the valve in question, any help appreciated.
http://www.tycoflowcontrol-pc.com/ld/R721_R723_12_03.pdf
Cheers.
