conversion of torque to force
Can someone tell how much is the force applied by a 1.5 inch dia bolt torqued to 420 N.m (Newton.meter) ?
conversion of torque to forceconversion of torque to force(OP)
Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesWhat is rapid injection molding? For engineers working with tight product design timelines, rapid injection molding can be a critical tool for prototyping and testing functional models. Download Now
The world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
RE: conversion of torque to force
T = F/1000 [p/2pi + u(Rm+r)]
where
T = Torque Nm
F = Bolt Load N
p = thread pitch mm
u = coeff friction (0.1 to 0.2 typically)
Rm = mean thread radius mm
r = mean nut bearing radius mm
u will vary considerably depending on type of lubricant, finish and fit of threads.
jt
I used some on-line calculators and arrived at 5.6 Tons. Is this right ?
Keep in mind that translating torque on nuts to force on a bolt is a very rough calculation. There are too many details involved (friction/lube, tolerances, temperature, phase of the moon) to pretend that the correlation is extremely accurate. Close enough usually is. If not, use stud tensioners, direct tension indicators, etc.
jt
phase of the moon ???
Yeah, it get the picture ... it is a very rough calculation.
where:
T = in lb
d = nominal size of a UNC bolt (e.g. .75 for a 3/4-10 bolt)
W = lb of induced load
