Shotcrete and Bonding Agent
I was called in to look at a 5 yr old commercial structure, one story 60'x84' with a basement. Flat site except for west side which slopes up (vehicle traffic surcharge on east and south sides). Wood framed roof and walls, 2-1/2" conc. slab on mtl deck and bar joists at ground level. Basement slab is SOG. Floor-to-floor hgt = 11'-0". Soils report says at rest EFP = 45pcf. The fdn wall is 8" thick reinf w/ #4 at 24" oc, centered (d=4"). Not surprisingly, every wall has a mid-height horizontal crack. The engineer who designed it has had his license revoked for other, even worse designs. My plan is to shotcrete a sister wall on the inside. I need bond btwn existing and new. I am specifying the existing surface to be roughened to proper amplitude but is there a additive that can be used to increase bond? Maybe a latex modifier?
RE: Shotcrete and Bonding Agent
http://www
...but they may not really be needed. See Question & Answer #6 and #29 at this link
http://www.shotcrete.org/ASAfaqs.htm#Q6
www.SlideRuleEra.net
