Section I or VIII?
Section I or VIII?
What is the difference between a Safety Relief Valve manufactured to ASME I vs. ASME VIII as far as deign and function? This would be for steam service at pressure below 250 psi.
RE: Section I or VIII?
You may want to try the "Boiler and Pressure Vessel Engineering" forum under Mechanical Engineering since you have no response here.
Good luck,
Latexman
