Locking tabs
Locking tabs
So, we know that the general consensus of the forum here is that split-lock washers don't work.
How do we feel about locking tabs? You know, the relativley soft metal plate that you bend a tab up against the flat of the nut, and another tab down against something else.
RE: Locking tabs
RE: Locking tabs
If you know the in-service load environment you should design the preload and joint design such that they will survive without locking devices. If you don't know the service environment, I have had better luck using one of the thread adhesives that are available. They will prevent relative motion of the threads and will not encourage embedment.
Good Luck,
Dick
RE: Locking tabs
We also use locking tabs on some SS fasteners on very large Centrifuges. The machines are all SS and are subject to vibrations problems.
Here is a interesting variation of the locking tab that I picked up on in another forum. I didn’t record the posters name.
http://www.stage8.com/howitworks.htm#
RE: Locking tabs
Screwman correctly picked up on my main concern. Any ideas how it might be possible to evaluate how much crushing/flow of the soft material happens during the initial tightening, and how much might continue to occur over time?
RE: Locking tabs
More recently, I bought a van with fancy wheel covers retained by bolts threaded into dead soft cross- straps, the ends of which were retained by two wheel nuts. The first time a wheel nut fell off, I threw away the wheel covers. A wheel nut's conical seat would make things difficult, but for a regular nut, it should be possible to analyze how hard the tab has to be.
I'm still a big fan of Loctite where temperature permits.
Mike Halloran
Pembroke Pines, FL, USA
RE: Locking tabs
bend up one corner on the bolt flat, bend long part down over an edge, or use a long one for 2 bolts, bend up a corner on each.
