Load everything on the screen
Is there a way to load everything on the screen, meaning, load everything that's under the trees.  Rather than load individual part or product when they are double-clicked, just load them when the file is initially opened.
thanks
RE: Load everything on the screen
Go in tools / options / general // general : Load referenced documents = ON
Eric N.
An other way is to turn off the cache
If you have the cache turned on, simply right click on the top product, go to Representations, and select "Design Mode".  That will switch everything under that node to Design Mode.
