Problem with Drawing Formats
Hi Folks,
I recently set up standard drawing formats for our company.
When I bring these into a drawing, all entities that were created with the 'Drawing Sketcher Tools' tool bar, namely straight lines and circles are lost. I used these features to create such things as the page border, ‘third angle projection symbol’ etc.
From what I remember, these are imported into the drawing initially when the format is used. Somewhere along the line they are lost with updates to the drawing etc. Incidentally, there are no problems with tables and the text within, only drawn entities.
Any comments welcome!
Speedy
Speedy
RE: Problem with Drawing Formats
Are these on a layer, try turning all the layers on.
Another thing to try is view, update all sheets. There are some config.pro options that may need to be set or changed, not sure which ones yet.
Tofflemire
I have done all that you suggested; "show format", all layers on,"view/update all sheets". Still no good!
I have checked the source format file and it still has those entities.
What does the "format_setup_file" do,in the Config_pro do ?
Is it similar to a *.dtl but specifically for a format?
Speedy
Steve
http://www.sprdesign.com
http://www.3dlogix.com
I checked "pro_format_dir" and it is set correctly.
I even tried re-inserting the formats, i.e. /File/Page setup/, and yes those missing entities are there when re-inserted.
Speedy
-Hora
