Handrail 200 lb force
Osha codes and IBC codes require that handrails can sustain a 200 lb force. One of the codes, but not the other, includes "200 lb force in any direction".
Any direction of course includes vertical force. This is easily accomplished by pinning the handrail at the base. How about the situation where want to easily remove a section of the handrail?
Which code governs?
Which code governs?
RE: Handrail 200 lb force
Cheers
Greg Locock
If you go with the spirit of the code, you could accomplish your "removable" handrail in one of two ways:
1) pin / bolt / 1/4 turn / removable fasteners ...... this handles the "any direction" but takes effort to remove
2) pipe inside a pipe.......think about this one for a second. If you have a 2" stub up with the rail post inserted over it, have you accounted for someone falling in an upward manner. No, it would be to easy to displace the rail. But if you had a 12" stub, it is improbable for someone to fall (or lean) in an upward manner that would slide the rail posts for 12" in an upward direction and so you have met the spirit of the code.
This was a long rambling statement, but was my thought process when I read your post.
ZCP
www.phoenix-engineer.com
"I think there is a world market for maybe five computers."
Thomas Watson, chairman of IBM, 1943.
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
In the old days, that's about 16 stone, if I recall my time is Oz correctly.
Steve Braune
Tank Industry Consultants
www.tankindustry.com
Cheers
Greg Locock
The general assumption is that the 200 lbf. is applied at any point, generally in a horizontal orientation as the vertical direction is not the primary direction for intended resistance. The handrail is intended to resist lateral movement. As for the open section of handrail, just make sure the connection does not compromise the lateral force resistance and it should be OK. It is commonly done for mezzanine loading operations.
I was a little reluctant to raise a question which seems so elementary.
I would like to add to this by saying I would check z-axis bending for angles since that would be the weakest condition. Also I like to interpret the handrail spec conservatively because I don't do enough of it to add any real cost when compared to detailing, fabrication, and installation issues.
Actually today I am going to be checking OSHA for handrails using angles because my recollection is that the criteria is 200# but not less than a L2x2x3/8 angle. My boss says that's for eight foot spans and a smaller anlge can be used for shorter spans if the 200# load is met. For the intermediate rail he uses a flat bar.
-Mike
Now I'll get on my terminology soapbox for just a second...
I know it may seem a silly distinction, but a lot of folks use the terms "handrail" and "guardrail" incorrectly.
A handrail is one single sloping rail that your hand grips as you go up or down a ramp or stair. A guardrail guards your life by preventing you from falling off of one place to a place you'd rather not go. (IBC calls it a 'guard', and OSHA calls it a 'standard railing')
A handrail may be affixed to a wall, or it may be affixed to a guardrail. In some instances, the top rail of a guardrail may do double duty by also serving as a handrail.
Getting back to the load issue...
Per IBC, some guardrails are taller than the handrails that are affixed to them, and in this instance, the 200# needs to be applied to the top of the guardrail AND to the handrail, though not simultaneously.
In all cases the handrail needs to be able to resist the 200# and transmit it to whatever the handrail is attached to (be it a structure or a guardrail).
In all cases, the 200# is a concentrated load. As an alternate to this concentrated load, a uniform load of 50 pounds/ft also needs to be considered. Again, it is applied to the handrail and the handrail needs to resist it and transmit it. It also is to be applied to the highest point on the guardrail. For a handrail attached to a taller guardrail, you'd first check to see that the handrail works for its 50#/' load, then take that load away and check the guardrail for a 50#/' load. Often the 50#/' load will govern over the 200# load because posts and handrail brackets are often spaced at over 5' on center.
Good grief.
Right offhand, I don't recall if OSHA even specifies a load. I know they specify the 2x2x3/8 angle or member of equivalent bending strength or 1.5" OD standard weight pipe.
As you suggested I did the search and want to point out to others here that thread507-92825 contains some good info plus some interesting links. I will be spending time later to go over a few of these.
JStephen,
I agree, the flat bar doesn't meet the OSHA requirements. Also, The L2x2x3/8 angle is a minimum size and the 200# is the minimum load. Period. IMO.
-Mike
Just wanted to make sure my statement was clear. It made sense to me at the time.
-Mike
