shaftpot v trimpot
shaftpot v trimpot
can i take a 5k trimpot and replace it with a 5k shaftpot?
RE: shaftpot v trimpot
The unit's only adjustment to control speed is by removing the cover and adjusting the trimpot. I would like to fit a shaftpot and protrude it through the cover. The trimpot has 3 conections.Thanks
may be under line voltage !!!!!
<nbucska@pcperipherals.com>
I am trying to work out a position scale around the shaftpot where it protrudes through the cover (eliminating the need to open the cover to reset the motor speed)indications are it wont be equal graduations yet if it is correctly marked any technician should be able to adjust it.
The load is constant per RPM.Thanks
