internal building wall pressure
What is the point of the second term for internal building pressure in the ASCE7 equation 6-17 for calculating applied wind loads???
Pz = q G Cp - q G Cpi
If I apply all positive (or all negative) pressure to the inside walls, the net result of adding the leeward and windward components is exactly the same as if I never used the term.
RE: internal building wall pressure
The internal coefficient also affects the overall uplift forces on the structure through the roof loads.
regards,
chichuck
