IGES format imported into SW
How do you edit a feature of an assembly that is imported into SW from Autocad. In the feature manager tree there is an IMPORTED icon for every part but when I try to edit a feature a dialog box opens prompting to open a file and the default file type is IGES?  HELP
RE: IGES format imported into SW
Do you have the Feature Recognition module in SW? If so use it when importing the part files.
cheers
Helpful SW websites  FAQ559-520
How to get answers to your SW questions  FAQ559-1091
No I don't have the feature recognition module and when you search the SW website ... Nada...???
FeatureWorks is the add-in you need. Otherwise you can simply make Dumb Geometry into smart geometry.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
There are actually a few things you can do to really edit imported geometry, such as replace face, move face, delete face (for solids) and untrim, delete hole, delete face (for surface).
I have a user group presentation on working with (meaning editing) imported geometry without using the "quirky" FeatureWorks.
http://mysite.verizon.net/mjlombard/  Go to the User Group link.
matt
