Adding more values to Multiple Value parameter
I have a string parameter I've created w/ 4 multiple values. Now I'd like to add another value to the drop down listing. Cannot determine how to do this. Do I need to delete the parameter and create it again?
Thanks....
Thanks....
Fighter Pilot
Manufacturing Engineer
RE: Adding more values to Multiple Value parameter
No, you can update your values. In your tree doulble click your parameter. In the dialog box right click on the pull-down value box and select update values. Now you can add and/or delete values. If your parameters are not shown in you tree, then go to "tools, "options", "infrastructure", "part infrastructure" and here to display. Check the parameters box. Yo can also edit the value the same way in the formulas: parameters area by right-clicking on the value and selecting "update values".
Cheers, Gary.
That's what I was looking for. I also found that if I create a Design Table, a new parameter can be added there as well.
Thanks...
Fighter Pilot
