Modeling real-life fill-up in boxes
Hello all,
how does one find out how many pieces of a part will fit into a box without actually trying it?
There are 3D nesting tools out there that OPTIMIZE the packaging of irregular parts in boxes. What I need though is something that simulates REAL-LIFE packaging of irregular parts. By packaging I mean simply throwing the parts into steel-mesh bins.
The parts are modelled in Catia V5. They're mostly weldments. What I need is: For a particular bin, how many of that part will fit if the parts are placed into the bin randomly?
RE: Modeling real-life fill-up in boxes
I don't know how to tell you to get the "best case" scenario, but that seems to be quite a complex analytic, at any rate.  I don't know that I've ever heard of something that manipulates solid geometry based on probability.
I'm not a mathematician - but if your part is anything other than spherical, it sounds like your variations would be infinitely variable, and thus, altogether incalculable.
Why, if I might ask, would you need to derive the volume of a steel mesh bin?  For me, I think of parts bins in a factory, but I notice that your tag is agricultural. (I assume that means farm equipment or grain processing)  Could you elaborate?
Check out CATBlog!
I do not need the "best case" fill rate. I need "as in life" fill rate. The parts in question are components of combine harvesters, tractors, etc. I need the real fill rate to put into SAP as part of our Kanban system.
